Home > In Car Electronics > Reversing camera
garethmorgan50
Reversing camera
I've read on various threads in the past of people fitting reversing cameras into the holes on the rear crossmember. I've had a look on eBay and there are several cheap cameras available. Can anyone recommend a cheap camera that does the job well and fits the holes. Also, do any of these cameras record images onto sd card??
Post #337464 11th Jun 2014 11:04am
Krackers
Australia 2013 Defender 110 Puma 2.2 SW Corris Grey
I also would be interested to hear responses to this thread. Additionally have people connected a reversing camera to a Garmin GPS unit?
Post #337467 11th Jun 2014 11:12am
Eduardo
garethmorgan50
I Installed a cheap one bought in USA for less than 20 USD.
I cut the support to install it in the hole of the cross member.
Until now and after some wading the camera are working OK. To feed up the camera I connect it directly to the reverse ligth and send the video cable to the front panel through the chassis to a screen (USD 16) that is located in the dash and feed up from the lighter cables.
http://www.amazon.com/gp/product/B0049LBJ5...&psc=1
http://www.amazon.com/gp/product/B0045IIZK...&psc=1
Total cost: around USD 36 + 1/2 day work
Cheers Eduardo
Post #337500 11th Jun 2014 2:08pm
ZeDefender
I fitted this into my rear crossmember:
http://www.ebay.de/itm/Digitales-Auto-Funk...3382f26392
(sorry it's in German)
The camera has been fitted into a very snug hole I drilled and fixed with epoxy putty (it's not going anywhere). Almost invisible. The receiver fits nicely in the corner of the windscreen (barely noticeable) and takes its power from the courtesy light (draws 40mA on standby but easy to unplug at the side).
It's a bit of a trade off as I have a NAS step and towball, so it's off centre (can't really judge side-to-side distances), but it makes it much easier to judge how far back you can go Thumbs Up Tell someone you love them today because life is short.
Post #337521 11th Jun 2014 4:41pm
glpinxit
I'm thinking of setting a number plate lamp type of camera into the number plate plinth. Various options here http://www.autobulbsdirect.co.uk/reversing-camera-kits/ Cheers, Guy.
Post #337780 12th Jun 2014 4:44pm
Davidatk
United Kingdom 2014 Defender 110 Puma 2.2 DCPU Santorini Black
We are just about to fit a camera done by Alpine, will let you know the cost etc, not sure it'll be cheap but you never know
Post #338195 15th Jun 2014 8:24am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Not sure if it works, but tempting to give it a try at this price:
http://www.dx.com/p/7-lcd-car-vehicle-rear...51kGBZjBZg
Post #338203 15th Jun 2014 9:16am
glpinxit
Lots of similar rear view monitor/displays on eBay including some that are more consistent with the size of the standard mirror. Has anyone tried using one? I'm interested to hear if they are a viable option. I suspect you lose the dipping mirror too? Cheers, Guy.
Post #338461 16th Jun 2014 1:02pm
ZeDefender
Don't know about you, but on mine and many others the dipping mirror is Censored . Viewing angle is all wrong.
Perhaps check yours before worrying about it... Tell someone you love them today because life is short.
Post #338464 16th Jun 2014 1:20pm
We installed the customers own mirror / monitor here:
http://www.defender2.net/forum/topic21668....;start=120
zahy wrote:
LandRoverAnorak wrote:
Blimey, that's a lot of leather Shocked
fotgot to add other bits trimmed in leather Laughing
rear speakers with usb and socket connection on both sides
rear reverse cam fitted by FCX
Rear seats in plastic replaced with leather
genuine SVX gear supplied by Dan duckworth land rover excellent service and of course trimmed AND FITTED by FCX
REAR VIEW MIRROR/CAM fitted by Matt with two cam one positioned externally covering the side traffic for blind spot and the second cam covers the rear - keeping an eye on my dog while driving
Post #338468 16th Jun 2014 1:31pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
I have one fitted to the under side of the number plate light mounting block. I have made a loom to add to the reverse light loom to switch it on. This way it is easier to remove and put back to std at little cost, that is if I ever sell it...... 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #338512 16th Jun 2014 5:26pm
