![]() | Home > In Car Electronics > No phone talk on standard XS Alpine Bluetooth |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
I would check the 3.5mm jack plug at the rear of the unit is plugged in correctly.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
As above, check connections / disconnect / re-connect.
See if that ones the trick. |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
Have you tried pairing an alternative handset just to eliminate your iPhone?
If you can hear them, then the only one you need to check at the back of the head unit is the mic connection. Also make sure you select the unit on your phone as the method of taking the call.
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 ![]() ![]() |
Thanks for the suggestions. It was the jack plug - not properly pushed home.
Cheers Gents. If only all my problems were so easily solved! Cheers, Guy. |
