Home > In Car Electronics > Hidden FM antenna |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Why not bung a Disco / RR / FL sharkfin on the roof? Should fit nicely on the slope at the front, without increasing overall height.. ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
23rd Jun 2014 10:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
Bear in mind with above you only have two options, offset or twin.
You cannot have a centralised one due to support rib in the centre.. |
23rd Jun 2014 11:12pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Well you could have it centred if you drill through the rib and then add a couple of strengthening plates either side of the rib Russell
2011MY 110 XS USW Black |
24th Jun 2014 5:43am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Is the radio aerial in the fin..?
On my D4 I thought the radio aerials were the wires in the two rear side windows. I always thought it was the GPS aerial in the fin..? But clearly I've no real idea.. Cheers Simon |
24th Jun 2014 5:48am |
The sharkfin is a GPS antenna Darren
24th Jun 2014 5:55am |
with the sharks fin radio aerial they are normally amplified , so you need to have power up there as well
you can get cheap ones that are not amplified but guess they would not work very well |
24th Jun 2014 6:12am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
The whole idea was to not have to drill another hole for antenna
I may as well replace the stock antenna in the original position and mount the CB on the rear using a PSM-1 mount |
24th Jun 2014 2:12pm |
There is internal stick on, usually on the glass but they can often differ in quality.
24th Jun 2014 3:07pm |
