Home > In Car Electronics > MudUK Tunnel Tray USB Port, how do I wire up?
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Is it easy for a non-electrical person like myself to install a USB Port by running the supply wire direct from the fusebox? under the transmission tunnel matting and use the spare fuses within the fusebox to provide a fused supply, and how do I do this? 2001 90 TD5 CSW Alveston Red Manual
Post #335818 4th Jun 2014 9:02pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
If you take the fusebox cover off, you can push the wire up in the top right corner and it should pop out where the wires for the radio and cigarette socket come out.
From there you can take a direct spur for both negative and positive from the cig socket which is ignition controlled.
I've got all sorts of stuff using this route Thumbs Up
Post #335868 4th Jun 2014 11:37pm
timtom1
thanks I will have ago and take pictures Smile 2001 90 TD5 CSW Alveston Red Manual
Post #336108 6th Jun 2014 6:33am
