Home > In Car Electronics > MudUK Tunnel Tray USB Port, how do I wire up? |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
If you take the fusebox cover off, you can push the wire up in the top right corner and it should pop out where the wires for the radio and cigarette socket come out.
From there you can take a direct spur for both negative and positive from the cig socket which is ignition controlled. I've got all sorts of stuff using this route Click image to enlarge |
4th Jun 2014 11:37pm |
timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148 |
thanks I will have ago and take pictures 2001 90 TD5 CSW Alveston Red Manual
6th Jun 2014 6:33am |
