Home > Puma (Tdci) > Road noise through door
spudfan
Ireland
The troops have often commented how we had noise comming in through the second door passenger side on our Puma 110. It was most noticable on wet road where you would hear lots of splashing as if the window was down slightly. Had the door checked by the dealer and it was fitted o.k. and the window was fine. To cut a long story short I found the problem. The bottom rubber on the door was a little long long and it overlapped the door frame rubber being pushed out in the process leaving a little gap for sound to enter the vehicle. A simple snip with the scissors solver the problem. Might help somone else. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #28107 26th Mar 2010 11:35am
alantd
Indeed. I have a slightly different problem - I can see the road through the bottom seal on the door Smile
I think mine might be a bit short. One that started out as a 2.4 TDCi 110 XS
Post #28122 26th Mar 2010 1:25pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
i get the same noise, i'll check it today.
Post #28123 26th Mar 2010 1:26pm
Grockle
try adjusting the striker 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #28124 26th Mar 2010 1:29pm
K9F
Bit You Snipped Off!
Spudfan any chance you kept the little bit you snipped off? Think I may know of a fellow site member that can make use of it!
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28127 26th Mar 2010 1:39pm
alantd
Re: Bit You Snipped Off!
Rolling with laughter Big Cry Rolling with laughter One that started out as a 2.4 TDCi 110 XS
Post #28131 26th Mar 2010 2:07pm
spudfan
Ireland
Afraid not. It is currently tied down in the back of the Puma, using the tie down rings to take to recycling. Always new those tie down rings would come in useful someday. Very Happy 1982 88" 2.25 diesel
Post #28139 26th Mar 2010 3:51pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I have the same noise issue as well. For a time I though that the door was open.
Post #28140 26th Mar 2010 4:01pm
K9F
Eutek,
I could possibly say that being the stature you are I'm surprised you can get the door shut at all! Rolling with laughter But having never met you, not knowing your size and being a fatty myself I'll not bother!
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28160 26th Mar 2010 6:38pm
fekete
Rolling with laughter Rolling with laughter Makes 3 of us Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #28166 26th Mar 2010 7:00pm
AndrewS
You need a hole in the seal Thumbs Up It lets the water out Thumbs Up
Honest Thumbs Up 130's have feeling's as well you know Smile
Post #28167 26th Mar 2010 7:00pm
munsterlandy
Ireland 2008 Defender 130 Puma 2.4 HCPU Santorini Black
evening all.
have similar experience regarding road noise.
very close inspection found that there is a lack of sealant between the seat box and side panel. clear view of the road from inside!!
no water ingress though Very Happy about the only place it not coming in though Big Cry and cant get dealer to take it seriously.
Post #28190 26th Mar 2010 10:37pm
MK
Indeed it`s that- just thrown-seal. I applied some silicone and problem fixed. Puma 110" SW
Post #28197 26th Mar 2010 11:37pm
AJS4X4
Well it is a Defender after all. Rolling with laughter
Andy.
Post #28206 27th Mar 2010 7:41am
eutek
K9F wrote:
Eutek,
Ahem... I'll have you know that I'm actually on the road to siimsville... I'm down to a mere 90kg, I'm a veritable feather compared to my former self. Laughing
Post #28339 29th Mar 2010 7:45am
