Home > Puma (Tdci) > Road noise through door |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4648 |
The troops have often commented how we had noise comming in through the second door passenger side on our Puma 110. It was most noticable on wet road where you would hear lots of splashing as if the window was down slightly. Had the door checked by the dealer and it was fitted o.k. and the window was fine. To cut a long story short I found the problem. The bottom rubber on the door was a little long long and it overlapped the door frame rubber being pushed out in the process leaving a little gap for sound to enter the vehicle. A simple snip with the scissors solver the problem. Might help somone else. 1982 88" 2.25 diesel
26th Mar 2010 11:35am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Indeed. I have a slightly different problem - I can see the road through the bottom seal on the door
I think mine might be a bit short. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
26th Mar 2010 1:25pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
i get the same noise, i'll check it today.
26th Mar 2010 1:26pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
try adjusting the striker 2.4 90 XS
26th Mar 2010 1:29pm |
Spudfan any chance you kept the little bit you snipped off? Think I may know of a fellow site member that can make use of it! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Mar 2010 1:39pm |
26th Mar 2010 2:07pm |
Afraid not. It is currently tied down in the back of the Puma, using the tie down rings to take to recycling. Always new those tie down rings would come in useful someday. 1982 88" 2.25 diesel
26th Mar 2010 3:51pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I have the same noise issue as well. For a time I though that the door was open.
26th Mar 2010 4:01pm |
Eutek,
I could possibly say that being the stature you are I'm surprised you can get the door shut at all! But having never met you, not knowing your size and being a fatty myself I'll not bother! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 27th Mar 2010 8:36am. Edited 1 time in total |
26th Mar 2010 6:38pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
You need a hole in the seal It lets the water out
Honest 130's have feeling's as well you know |
26th Mar 2010 7:00pm |
munsterlandy Member Since: 17 Dec 2009 Location: munster Posts: 52 |
evening all.
have similar experience regarding road noise. very close inspection found that there is a lack of sealant between the seat box and side panel. clear view of the road from inside!! no water ingress though about the only place it not coming in though and cant get dealer to take it seriously. |
26th Mar 2010 10:37pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Indeed it`s that- just thrown-seal. I applied some silicone and problem fixed. Puma 110" SW
26th Mar 2010 11:37pm |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 |
Well it is a Defender after all.
Andy. |
27th Mar 2010 7:41am |
Ahem... I'll have you know that I'm actually on the road to siimsville... I'm down to a mere 90kg, I'm a veritable feather compared to my former self. |
29th Mar 2010 7:45am |
