- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ZeDefender
In their infinite wisdom, LR use M8 studs coming out of the sides of the fender (2 each side) with nuts on the radiator side to fix the bonnet slam panel on. They have to come out or there's no room to remove the panel. Some people manage with grips but I had an A-bar getting in the way and crap grips. It also mashes the threads so you have to replace them with new studs or bolts (more sensible) anyway. On the other hand, once you've undone one nut you can use it to lock the others and get all studs out. I had no trouble doing this Tell someone you love them today because life is short.
22nd May 2014 8:24am |
