![]() | Home > Td5 > Bare wire next to ecu. |
Don't worry too much, mine's the same. It might be Land Rovers way of shedding the oil that travels down from the injector harness. It goes into shrouded insulation as it goes into the loom. One of LR's little mysteries.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Mine was the same
Looks like the termination of a sheilded cable (probably cam or crank sensor wires) I wouldnt worry about it.
Steve |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Mines the same,assumed its an early warning feature for oil in loom
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Cheers everybody...that's one less thing to worry about. 2002 110 td5
