![]() | Home > Maintenance & Modifications > Help required - Hand Brake Sticking On |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Hi,
Over the last couple of days the handbrake seems to have stuck on a couple of times. Drove around the block and it came off. ![]() Is this a common fault, is there a simple trick to get it to release, is it knackered? ![]() Thanks Guys in advance ![]() Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
Mine was doing the same
Took it down to the mechanic and he sorted it in 5 mins - think he just pulled the cable through from below the car Not a big deal but I didn't have time (or energy) to sort it myself |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
Change for an X brake
Simples Andy |
What's an X brake? Defender 90 TD5 Station Wagon
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Here
http://www.x-eng.co.uk/X-BrakeDef.asp NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Adjusted the handbrake yesterday, both the shoes and cable - now a lot less play.
So far so good appears to be working fine ![]() If this doesn't work it will be off with the propshaft ![]() Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
Wrong!!
Stuck on again today ![]() And since I have adjusted the handbrake - they actually work ![]() Work in progress ![]() steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
