![]() | Home > Technical > differential guard question |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
The change in 2002 was for 110 and 130 axles which are heavy duty. As far as I know, the 90 uses the same axle front and rear, and always has, so buying two diff guards for a 90 should be simple. 1998 110 300Tdi White Hard Top
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Hopeing to be buying a pair for my 90 at billing in a couple of months time
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
easydeluxe Member Since: 18 Nov 2013 Location: antwerp Posts: 55 ![]() ![]() ![]() |
what i thought, thx for the confirmation ![]() |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 183 ![]() ![]() ![]() |
My advice, based on experience, would be put plenty of grease on the threads. They are a sod to get off later if you dont!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
What diff guards were you thinking of?
praetorian Member Since: 01 Jul 2014 Location: Newcastle Posts: 6 ![]() ![]() |
The Terrafirma front guard for your car is a great piece of kit, but at present the rear isn't the same design, so I'm guessing a different supplier.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The paint is a luxury I know and will get damaged. I've had them on for a year now and they've don't their job as there is the odd bang they've taken and I haven't really been off toad with them either! Easy enough to touch the paint up, little artists brush with a model enamel 14ml paint pot of gloss black and any marks are rapidly covered up in seconds for pennies. Not that anyone goes around checking diff guard paint, although some of us that are a bit whacky would. ![]() ![]() |
