Home > Technical > differential guard question
easydeluxe
Belgium 2008 Defender 90 Puma 2.4 HT Epsom Green
I want to order diff guards for my 2014 90.
Are the front and rear diff still the same?
The info I find about this is confusing.
What changed from 2002 onwards?
The diffs look the same to me when i'm under the car?
So ca two identical rover diff guards fit the front and the rear on my new 90???
thx!
G
Post #331516 17th May 2014 8:20am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
The change in 2002 was for 110 and 130 axles which are heavy duty. As far as I know, the 90 uses the same axle front and rear, and always has, so buying two diff guards for a 90 should be simple. 1998 110 300Tdi White Hard Top
Post #331520 17th May 2014 9:03am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hopeing to be buying a pair for my 90 at billing in a couple of months time Very Happy Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #331583 17th May 2014 2:42pm
easydeluxe
what i thought, thx for the confirmation Thumbs Up
Post #331624 17th May 2014 6:44pm
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
My advice, based on experience, would be put plenty of grease on the threads. They are a sod to get off later if you dont!
Post #338801 17th Jun 2014 6:52pm
What diff guards were you thinking of?
Post #338804 17th Jun 2014 6:56pm
praetorian
The Terrafirma front guard for your car is a great piece of kit, but at present the rear isn't the same design, so I'm guessing a different supplier.
Post #342144 1st Jul 2014 9:14pm
The paint is a luxury I know and will get damaged.
I've had them on for a year now and they've don't their job as there is the odd bang they've taken and I haven't really been off toad with them either!
Easy enough to touch the paint up, little artists brush with a model enamel 14ml paint pot of gloss black and any marks are rapidly covered up in seconds for pennies.
Not that anyone goes around checking diff guard paint, although some of us that are a bit whacky would. Rolling with laughter
Thumbs Up
Post #342172 1st Jul 2014 11:00pm
