Home > Td5 > Bag of spanners!
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Bag of spanners!
Got a running issue at the moment (02 plate Td5), i.e. No oomph.
It will not rev out, there is a bit of a screech (sometimes), bit of a misfire (sort of). This is whilst driving with a slightly heavy right foot.
If I drive smoothly through the gears, keeping the revs down, I can get up to about 40 mph.
Whilst stationary and I try to rev her up, I get all of the above symptoms plus smoke.
Investigation gives me a delaminated turbo hose.
Now, the question is this, are my problems all down to the hose or is there something more deep seated to be hunting? It wasn't me!
Post #330248 11th May 2014 3:03pm
excossack
I would start with the hose and go from there. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #330259 11th May 2014 3:39pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Have you tried it with the Air Mass Meter unplugged.
Post #330317 11th May 2014 5:39pm
ozzy57
Good points both.
Fair enough point Excossack, eliminate the known fault before I go looking for unknowns.
Skeggy 90, absolutely no point doing that until the failed hose is replaced, it's running bad enough as it is. It wasn't me!
Post #330326 11th May 2014 6:08pm
JWL
With your love of dipping more than a toe in the water, have you looked at the air filter? Even though I have a "snorkel" it doesn't mean that it's sealed!
Post #330337 11th May 2014 6:42pm
bob neville
I take it that you have checked the red plug on the ECU for oil ingress through the injector harness ?
2013 Defender 90 CSW - sold
Post #330338 11th May 2014 6:43pm
ozzy57
Filter dry, as is the ECU.
But the hose to the turbo is first port of call. I've had it out and it looks like a bag of plums on the inside. It wasn't me!
Post #330361 11th May 2014 7:37pm
excossack
Not sure engines can run on plums... 1999 Defender TD5 110
Regards
John M0VAZ
Post #330364 11th May 2014 7:46pm
ozzy57
.....which is why I'm having problems....... It wasn't me!
Post #330372 11th May 2014 8:03pm
ozzy57
Got to the bottom of it, I hope. It's a combination of EGR failure and MAF sensor failure.
And for good measure, I find two exhaust studs broken. It wasn't me!
Post #330848 13th May 2014 8:05pm
