Home > Puma (Tdci) > Roof Spot light recommendation ?
Page 2 of 3 <123>
keith
Good choice . Quality wins the day .
Post #329246 8th May 2014 10:41am
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
the pattern on the lens is very similar to the Hella Comet lights on the Tomb Raider Thumbs Up
Post #329247 8th May 2014 10:42am
SkyFallSilver
Kuwait
Lads I have a wire I got from eBay to wire 4 roof lights it says 55w x4 since the lights I have on the way are 100w ? 2016 Defender 90 Adventure Edition
Post #329269 8th May 2014 12:27pm
Maxxed_Ross
I wouldn't risk it, the 100W bulbs will draw more current - creating heat. If the wires are too thin they will overheat, melt and could start a fire.
The thicker the cable the better! Thumbs Up
Post #329353 8th May 2014 4:52pm
SkyFallSilver
Kuwait
Great thanks a lot, will try and do something similar to power all 4 lights with one button. 2016 Defender 90 Adventure Edition
Post #329391 8th May 2014 6:49pm
SkyFallSilver
Kuwait
Would it possible to have 2 Hella Wiring Harness power 4 aux lights lights within one switch button?
to this
Post #329518 9th May 2014 3:35am
SkyFallSilver
Kuwait
Anyone can help me with the above question ? 2016 Defender 90 Adventure Edition
Post #329718 9th May 2014 5:45pm
K9F
You will need to switch the lighting supply via a relay as the switch depicted will not cope with the current draw of your lights alone. Best practice is to switch the earth of the relay. Presumably the relays are supplied with the loom. If so the anwer to your question is a resounding YES! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329719 9th May 2014 5:51pm
Matthew_Mills
Where can I get one of those switches? I need to replace dealer fitted rubbish for a work light and that will do the job...
Post #329734 9th May 2014 7:26pm
stick a 40" or 50" light bar up there, lower power consumption and much better light Thumbs Up
Post #329762 9th May 2014 8:22pm
SkyFallSilver
Kuwait
I don't like the look of those, more suited to american trucks. 2016 Defender 90 Adventure Edition
Post #329768 9th May 2014 8:33pm
K9F
http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329792 9th May 2014 9:47pm
AS BP said :thumbsup:
Post #330214 11th May 2014 12:30pm
kmac
Fifty quid for a switch? Got the heated seat switch on that site for £44 for £5 from Dan at Duckworth parts
Post #330226 11th May 2014 1:42pm
SkyFallSilver
Kuwait
ken wrote:
AS BP said Thumbs Up
I have seen the light, honestly after fitting Nolden headlamps I have never thought one single upgrade would be strong
Its Bi-LED so, high and low beam
My Roof Rack lights will be Hella 4000 Halogen
My Nudge Bar lights will be Hella 4000 Luminator LED
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2016 Defender 90 Adventure Edition
Post #330379 11th May 2014 8:11pm
Page 2 of 3 <123>
