![]() | Home > Td5 > Screeching / Chirupping noise... |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
So all the UJs were pretty dry, packed with grease and initially it seems to be ok... Fingers crossed! I'm amazed the joints make that noise tbh.... Hopefully its a cheap fix! Cheers
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
Ujs do chirp when suspect! also the only REAL way to inspect the Uj is remove the prop! i had same on my d2 td5 UJ seems OK on car checks, took it off to find it was seized in one direction!!! My 109 thread
my youtube channel |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 ![]() ![]() ![]() |
This squeak of mine developed into a louder squeak, then transmission vibration.
![]() New UJ fitted, and fingers crossed all seems good. Thanks for the heads up Landlord, it wouldn't have been in my mind to closely inspect there had the vibration not started! ![]() |
Just to update on this;
Greasing the UJs helped for a bit and then it got worse again. It then deteriorated into a pretty horrible out of balance. End result is the propshaft ends were badly worn. New prop and all sorted.... Another Cheers for you Landlord! |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Another chirrup and poor handling at 40-50mph resolved by a replacement UJ as diagnosed by John Dennis 4x4 last week just before MOT
