Home > Td5 > Screeching / Chirupping noise... |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
So all the UJs were pretty dry, packed with grease and initially it seems to be ok... Fingers crossed! I'm amazed the joints make that noise tbh.... Hopefully its a cheap fix! Cheers
8th May 2014 11:38am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Ujs do chirp when suspect! also the only REAL way to inspect the Uj is remove the prop! i had same on my d2 td5 UJ seems OK on car checks, took it off to find it was seized in one direction!!! My 109 thread
my youtube channel |
8th May 2014 5:22pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
This squeak of mine developed into a louder squeak, then transmission vibration. A closer inspection found slight play, and discolouration in one of the yokes on the rear prop ( diff end)
New UJ fitted, and fingers crossed all seems good. Thanks for the heads up Landlord, it wouldn't have been in my mind to closely inspect there had the vibration not started! |
14th May 2014 6:05pm |
Just to update on this;
Greasing the UJs helped for a bit and then it got worse again. It then deteriorated into a pretty horrible out of balance. End result is the propshaft ends were badly worn. New prop and all sorted.... Another Cheers for you Landlord! |
20th May 2014 12:19pm |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 |
Another chirrup and poor handling at 40-50mph resolved by a replacement UJ as diagnosed by John Dennis 4x4 last week just before MOT
20th May 2014 8:51pm |
