Home > Puma (Tdci) > Wheel bearing collapse noise?
Page 2 of 2 <12
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Post #326050 25th Apr 2014 8:06pm
willyj
Post #326051 25th Apr 2014 8:07pm
munch90
in the first picture where you can just see the brake calliper the pads look like they have been red hot by the colour of them , maybe wrong as its a bit hard to see
if they have is the brake binding on that wheel
Post #326108 25th Apr 2014 10:44pm
willyj
I've not had the defender long. So don't know what's happened. I'm thinking that the abs isn't working properly on it and its independently braking on that wheel? Perhaps that's why brakes look a little cooked? When it took the hub off, on the disk you could see that it's been "on off abs braking" marks on it if that makes sense?
Post #326115 25th Apr 2014 10:56pm
munch90
I don't think you would see any marks from abs braking as the pulsing is to fast and also when you put the brakes on the disc is in a different place each time so marks would never be in same place
the marks maybe from cheap worn discs with hard spots , or have overheated causing hard spots or distorting , bit hard to tell without seeing them
Post #326117 25th Apr 2014 11:05pm
munch90
have you had the bearings out to check the tracks as a bad gone bearing still could have no play you could feel
you only need a rough bit a few mill wide to give a noise and you would never feel that as play , and defender wheels are hard to spin by hand to hear or feel roughness
also is the noise in straight line or worse on bend etc ?
Post #326120 25th Apr 2014 11:14pm
willyj
Perhaps what i said didnt make sense. Umm. Rather than having a clean disk and a mark where the pad last made, you can see the "marks" on the disk all around it. In the years i have been repairing my machines and vehicles Ive not seen it before.
Ive had the hub out and checked bearings properly but found nothing. Noise is mostly apparent in a straight line when in gear, put in neutral and nothing.
Post #326171 26th Apr 2014 8:43am
munch90
do you mean there is a shape of the pad on the disc in diffirent places round it if so , I would say that's where it been park up with wet brakes and metal dust in pad material has rusted against the disc leaving marks on it , not uncommon if it has been washed and left to dry
and looking at the pads I would say they are binding a bit so would have excess dust and metal dust to rust
what about diff , maybe chipped or broken tooth on crownwheel or pinion , shouldn't be planet gears if noisy only in straight line
and diff what only really make a noise under load
Post #326175 26th Apr 2014 9:16am
Page 2 of 2 <12
