![]() | Home > Puma (Tdci) > Flakey paint on side and nas rear step. |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
Hi lads. Does anyone know if the paint on steps is covered under warranty?. At 2 years old the paint/powder coating is coming off in chunks.
Cheers, Richard. 1963 Series 2A truck cab 2008 110 SW |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
I think it is, if it isn't it seems like it should be... 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
Thanks for the reply. I'll ring them on monday anyway, I just wondered wether to buy the Hammerite or not yet
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
Thanks. fingers crossed pressure won't be needed. 1963 Series 2A truck cab 2008 110 SW |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I bet your dealer will say the flaking is caused by unattended stone chipping and wear and tear. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
If that is the case, whip 'em off and get them zinc washed and powder coated. Mine too the finish is coming off at the end adjacent to the wheel. Replacement under warranty would just be a 'sticking plaster' fix as another couple of years down the line you'll be very likely to be in the same boat anyway. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
If it was fit as standard it will have a full warranty. They do a full 'rust' check on services so should have picked up and stone chips then and rectified them then
Glyn |
Agreed. Had my rear step replaced on warranty because it was rusting. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
check your rear cross members too,some have hardly any paint on them,I had ours re sprayed as there was signs of rust after 6 months 2.4 90 XS
Thanks for your replies. I'll ring the dealers next week.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
You will find the step wont be covered if it wasnt fitted at purchase.
There are bits of rust on mine ive just dealt with myself. All parts get 12months warranty. There are bits of corrosion across mine i noticed on bits i havent coated - like the rear diff (pan and diff itself) prop shaft etc. Im drawing up a list for it to go in soon. To be honest i would treat any corrosion myself and quickly.
Im not sure they do rectify them - they are definately supposed to check for corrosion, but not fix...you have to be asked/or ask for it to be done. Mike |
