Home > Puma (Tdci) > Flakey paint on side and nas rear step.
YORKSHIRELAD
Hi lads. Does anyone know if the paint on steps is covered under warranty?. At 2 years old the paint/powder coating is coming off in chunks.
Cheers, Richard. 1963 Series 2A truck cab
2008 110 SW
Post #26720 13th Mar 2010 8:54pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
I think it is, if it isn't it seems like it should be... 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #26729 13th Mar 2010 9:31pm
YORKSHIRELAD
Thanks for the reply. I'll ring them on monday anyway, I just wondered wether to buy the Hammerite or not yet Razz
Richard 1963 Series 2A truck cab
2008 110 SW
Post #26734 13th Mar 2010 9:54pm
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I agree, warranty should cover it.
If you remember selling point of having accessories fitted at time or within one month of new vehicle purchase is that they have the same 3 year warranty as vehicle, rather than just 12 months, so warranty SHOULD definetely apply to original fitment steps.
Hope you don't have a dealer that needs pressure brought to bear!
Wish you well. 1981 series 3 swb gone
1986 v8 110 station wagon current
2009 puma 110 xs utility station wagon latest addition
Post #26746 13th Mar 2010 11:42pm
YORKSHIRELAD
Wish you well.
Thanks. fingers crossed pressure won't be needed. 1963 Series 2A truck cab
2008 110 SW
Post #26748 13th Mar 2010 11:50pm
RED-DOT
I bet your dealer will say the flaking is caused by unattended stone chipping and wear and tear. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #26757 14th Mar 2010 9:04am
K9F
Powder Coat Them!
If that is the case, whip 'em off and get them zinc washed and powder coated. Mine too the finish is coming off at the end adjacent to the wheel. Replacement under warranty would just be a 'sticking plaster' fix as another couple of years down the line you'll be very likely to be in the same boat anyway. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26759 14th Mar 2010 9:24am
Glynparry25
If it was fit as standard it will have a full warranty. They do a full 'rust' check on services so should have picked up and stone chips then and rectified them then
Glyn
Post #26772 14th Mar 2010 10:51am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Agreed. Had my rear step replaced on warranty because it was rusting. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #26787 14th Mar 2010 11:50am
Grockle
check your rear cross members too,some have hardly any paint on them,I had ours re sprayed as there was signs of rust after 6 months 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #26799 14th Mar 2010 1:46pm
YORKSHIRELAD
Thanks for your replies. I'll ring the dealers next week. Thumbs Up
2008 110 SW
Post #26812 14th Mar 2010 5:31pm
mse
You will find the step wont be covered if it wasnt fitted at purchase.
There are bits of rust on mine ive just dealt with myself. All parts get 12months warranty.
There are bits of corrosion across mine i noticed on bits i havent coated - like the rear diff (pan and diff itself) prop shaft etc.
Im drawing up a list for it to go in soon.
To be honest i would treat any corrosion myself and quickly.
Im not sure they do rectify them - they are definately supposed to check for corrosion, but not fix...you have to be asked/or ask for it to be done. Mike
Post #26837 14th Mar 2010 11:11pm
