Home > Maintenance & Modifications > Maxxraxx mounting to tow bar. OEM tow bar issue?
Jim_Bean
Hi Guys,
Can one of you Maxxraxx owners let me know how to correctly fit the foot to the OEM tow bar?
On my tow bar the rings either side of the tow bar get in the way.
I could use a much large spacer than the one supplied but that doesn't seem right somehow. I could also mount the foot really high up but that seems wrong too.
Could you offer some advice?
This is the problem :
Rings prevent the foot from sitting flush against the towing bracket.
Post #321616 4th Apr 2014 8:38pm
Mountain_man
Wales
Looks like 2 choices. Grind off the rings or fit a spacer between the foot and the dropper plate. Personaly would go with the latter.
Post #321618 4th Apr 2014 8:44pm
Jim_Bean
I guess the spacer is the way to go. Just thought i'd see what other people have done.
It will have to be quite a thick spacer. Won't this have a bearing on the overall towing capacity?
Post #321621 4th Apr 2014 8:50pm
fixit
I would probably cut the bracket and reweld with an off set as it only looks like the width of the plate and i have the tools to hand
But it would be easier to fit a spacer
Post #321668 5th Apr 2014 9:28am
Jim_Bean
Spacer ordered.
I guess i just won't do any heavy towing with the bracket and spacers attached.
Post #321680 5th Apr 2014 10:28am
Why would a spacer put you off heavy towing? Darren
Post #321702 5th Apr 2014 12:17pm
jeeves
I don't know if this helps but here is my set up with an adjustable tow bar
Post #321706 5th Apr 2014 12:47pm
excossack
Could you move it up level to clear the towing loop? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #321708 5th Apr 2014 12:48pm
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I bought a 25mm spacer block for mine and some extra long bolts 2013 Aintree Green 110 Station Wagon SX
Post #321724 5th Apr 2014 2:17pm
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Same again
Post #321778 5th Apr 2014 6:47pm
Neils
Sorry to necro a nearly 2 year old thread, but having just fit a rack this weekend and having ended up in this thread when working out what we needed thought I would just chip in with a few details.
Spot on with the 25mm spacer. You can get them with Maxxraxx but they are expensive at £17 for the spacer plus bolts, plus side is that it all comes together in one order I suppose. I found them around and about for £4-5+ £2 a pair for bolts. 90 or 100mm bolts on an M16 thread are what you're looking for. You don't need the full 100mm length but if you don't mind the extra turns, it buys you some slack for whatever you might be thinking of getting next.
What I didn't have much luck finding was a black coated/anodised spacer. For those, like me before I dismantled the towbar, who might not have a clue what the spacer is or looks like, you want one of these:
Post #539759 13th Jun 2016 12:33am
