Home > Maintenance & Modifications > E marking doubts
E marking doubts
Confused
I have RDX LED lighting all around on my 90 which I know are legal as they are E marked for purpose, however, I have LED bulbs in my side repeaters and number plate light.
With all this talk of type approval ect I'm thinking they are technically illegal so should I remove them and go back to incandescent?
Passing an MOT just because it isn't noticed and or not possible to check doesn't necessarily mean that that it's legal.
I would hate for if anything was to happen insurance to check it out and turn around and say your indicators are illegal and we won't be paying out.
My reasons for saying this is that let's take the side repeater as an example;
As standard, E marked fixture and E marked bulb.
As is I have an E marked fixture but no E mark on the LED bulb.
I was under the impression that if the fixture was E marked it was the correct colour and the light output was just as bright or brighter then all was good.
Help! Confused
(Really happy with it all but this issue is a worry) [There is no E marked LED side repeater for the Defender that is on the market and E marked number plate lamps for the Defender are rubbish, I had one and it failed in an hour]
Over this technicality the law could indeed be an ass. Neutral
Post #320132 29th Mar 2014 10:46pm
munch90
maybe the insurance company's should worry about the bogus whiplash claims more than what side indicator bulbs you got fitted .
what if you had a normal bulb fitted and it didn't work , the list could go on & on & on
Post #320134 29th Mar 2014 11:34pm
Indeed, they are a complete pain in the a** i do know.
Post #320141 29th Mar 2014 11:38pm
munch90
never go with the cheapest and check who the underwriters are
that's what I was told by mate you worked for big insurance company
Post #320144 29th Mar 2014 11:43pm
I'm with Aviva and paying plenty but I know they are reliable.
It's ridiculous all these little (and large) problems we have go deal with in this country.
Post #320145 29th Mar 2014 11:53pm
IMO it should be incandescent that should be banned not LED, incandescent can be useless compared.
The only downside is when cheapo foreign LED's are brought into the mixture.
Saying that incandescent bulbs can blow quickly too. Rolling Eyes
Post #320146 30th Mar 2014 12:00am
K9F
A light is a light. In all my years of automotive MOT experience I have never known a tester spend a significant amount of time looking for approval/kite marks on the smaller filaments and he certainly won't be removing anything to check. If it's lit you'll get your tick in the appropriate box and he'll move on rapidly as his list is long and time short.
If you're that worried return your truck to bog standard. If the insurance company want to be pedantic they'll always find some reason to dispute a claim. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #320162 30th Mar 2014 7:16am
Very true Mal! Thumbs Up
IMHO there are far far too many grey areas in motoring laws, many of which could simply be tied up and had done with so at least you know what is right and wrong.
Maybe having mud terrain tyres will be illegal next..
Post #320167 30th Mar 2014 7:33am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
A friend of mine on his last MOT had the following comments made by the MOT tester.
"I really should fail the vehicle as you have LED bulbs fitted in the standard side light fittings, however if I tell you to change them you would only put the LED one back in when and after it passes, so I will pass it anyway"
My feeling is that something that makes the vehicle safer without causing other road users a problem, possibly blinding or too bright, is a good thing. But for the cost of the RDX type sets which I have fitted why be illegal. They do a very nice number plate light which is LED at Bolt on Bits. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #320170 30th Mar 2014 7:51am
leeds
OK if a light comes out of the factory and is type approved, I.e. E marked then that type approval only stands for the type of light source in the light device.
Type approval is only required for obligatory lights required by law to be fitted to your vehicle.
Question are side indicator repeaters considered to be an obligatory light?
Brendan
Post #320173 30th Mar 2014 8:09am
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
http://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_1.htm
cant see any sestriction or requirements in here for led bulbs
Post #320180 30th Mar 2014 9:15am
leeds
Rich, LED's are not mention in the Vehicle Lighting Regulations correct.
There is a requirement for obligatory lights to be type approve which these days people say E marked.
So LED lighting devices which are E marked are road legal Thumbs Up
Incandescent/ filament lights that are E marked, correctly fitted etc are road legal Thumbs Up
Most of the LED clusters that are available aftermarket are not E marked.
Putting a LED cluster replacement in an E marked filament bulb holder is illegal as the obligatory type approval no longer applies.
Putting a LED in a non obligatory filament light is legal as type approval is not required.
Brendan
Post #320191 30th Mar 2014 10:00am
So where do I stand then?
I'm thinking the side repeaters are more likely an issue because they are most noticeable for a start.
Post #320192 30th Mar 2014 10:29am
The RDX led lights indicators brake lights etc are certainly legal because they are E marked from the factory. It's just the number plate light and side repeaters for me that have LED SMD bulbs in E marked holders.
Post #320193 30th Mar 2014 10:35am
mk1collector
Slightly off topic but if your worried about legalities/insurance/mot etc, I've just noticed in another post you've made that you have a metal a bar on the front of your motor. I thought it had been made illegal on puma onwards defenders to fit these in this country, hence the soft a bar from Landrover, or have I just dreamt it? Rolling with laughter I didn't think insurers would approve there use due to new regs.
Post #320196 30th Mar 2014 10:52am
