Home > In Car Electronics > Non-Insulated terminal crimping
GUM97
Hi all,
What's the best way to crimp non-insulated terminals?
I've tried ratcheting crimps, but they're a bit cumbersome for my liking. I've got a lot to do, so I need an easy way of doing it!
So what's everyone else using?
Regards
Pete An engine to TDi for!
Post #319126 25th Mar 2014 9:32pm
Basic crimping pliers? Or needle isle pliers if your careful. No Guts, No Glory.
Post #319134 25th Mar 2014 9:51pm
GUM97
The basic crimping pliers don't seem to do it very well? Or am I doing it wrong? Confused An engine to TDi for!
Post #319267 26th Mar 2014 5:38pm
Email me some photos. Thumbs Up No Guts, No Glory.
Post #319273 26th Mar 2014 5:55pm
What type of terminal are you trying to crimp?
Post #319275 26th Mar 2014 6:09pm
VeeTee
Netherlands
I use a normal rachet type crimping tool. Can't see whats wrong with it Shocked
 Cheers, Vincent
MySite
Post #319289 26th Mar 2014 6:56pm
K9F
Depends on size but these are excellent Durite specifically for uninsulated and affordable too..... Thumbs Up
http://api.viglink.com/api/click?format=go...Bbih%3D575 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #319310 26th Mar 2014 8:38pm
Mal, link appears to go straight to Google? No Guts, No Glory.
Post #319323 26th Mar 2014 8:53pm
K9F
What no tools shown? Works for me. If not Google 'Durite Crimping Tools'.....
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #319335 26th Mar 2014 9:11pm
GUM97
Mal- Link doesn't work for me either!
It's for 2.5mmSq. Wires, like these ones...
http://www.vehicle-wiring-products.eu/VWP-...gterms.php
I found the ratcheting type crimped them too tightly and the almost crushed them Confused An engine to TDi for!
Post #319348 26th Mar 2014 9:25pm
K9F
http://www.defender2.net/forum/topic17650.html?highlight=crimping If you go through life with your head in the sand....all people will see is an ar5e!!
Post #319363 26th Mar 2014 9:50pm
Well that link mentions Durite connector crimping but I've done mine perfect IMO with just a pair of needle nose pliers. No crushing but not loose either.
I don't see any need at all for buying any special tool unless it was a very large crimp that needed to be very tight. No Guts, No Glory.
Post #319373 26th Mar 2014 10:07pm
Romadog
I have a pair of these. Bought them for myself for Christmas.Worth it as it meant that I did the job properly rather than unsuccessfully with a pair of pliers
http://www.ebay.co.uk/itm/like/23067826692...amp;ff19=0
Post #319526 27th Mar 2014 5:16pm
munch90
most of the crimping tools you see just seem to crush the crimp and you wont find them in a aircraft electricians box, I always use the type that fold the crimp part in . they have a pointly bit that pushes in to crimp not just crush the end.
if you want a good pair get aircraft ones
Post #319529 27th Mar 2014 5:44pm
MartinK
I bought from here:
http://www.wirecrimpingtools.co.uk/categories.php?cat=14
I also bought different die sets ("jaws") so I can crimp other types of fasteners as well Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #319533 27th Mar 2014 5:49pm
