Home > In Car Electronics > Non-Insulated terminal crimping |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20546 |
Basic crimping pliers? Or needle isle pliers if your careful. KEEP CALM AND Drill ON
25th Mar 2014 9:51pm |
The basic crimping pliers don't seem to do it very well? Or am I doing it wrong? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
26th Mar 2014 5:38pm |
Email me some photos. KEEP CALM AND Drill ON
26th Mar 2014 5:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17516 |
What type of terminal are you trying to crimp?
26th Mar 2014 6:09pm |
I use a normal rachet type crimping tool. Can't see whats wrong with it
Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
26th Mar 2014 6:56pm |
Depends on size but these are excellent Durite specifically for uninsulated and affordable too.....
http://api.viglink.com/api/click?format=go...Bbih%3D575 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Mar 2014 8:38pm |
Mal, link appears to go straight to Google? KEEP CALM AND Drill ON
26th Mar 2014 8:53pm |
What no tools shown? Works for me. If not Google 'Durite Crimping Tools'.....
26th Mar 2014 9:11pm |
Mal- Link doesn't work for me either!
It's for 2.5mmSq. Wires, like these ones... http://www.vehicle-wiring-products.eu/VWP-...gterms.php I found the ratcheting type crimped them too tightly and the almost crushed them An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
26th Mar 2014 9:25pm |
http://www.defender2.net/forum/topic17650.html?highlight=crimping If you go through life with your head in the sand....all people will see is an ar5e!!
26th Mar 2014 9:50pm |
Well that link mentions Durite connector crimping but I've done mine perfect IMO with just a pair of needle nose pliers. No crushing but not loose either.
I don't see any need at all for buying any special tool unless it was a very large crimp that needed to be very tight. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 27th Mar 2014 5:35pm. Edited 1 time in total |
26th Mar 2014 10:07pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
I have a pair of these. Bought them for myself for Christmas.Worth it as it meant that I did the job properly rather than unsuccessfully with a pair of pliers
http://www.ebay.co.uk/itm/like/23067826692...amp;ff19=0 |
27th Mar 2014 5:16pm |
most of the crimping tools you see just seem to crush the crimp and you wont find them in a aircraft electricians box, I always use the type that fold the crimp part in . they have a pointly bit that pushes in to crimp not just crush the end.
if you want a good pair get aircraft ones |
27th Mar 2014 5:44pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I bought from here:
http://www.wirecrimpingtools.co.uk/categories.php?cat=14 I also bought different die sets ("jaws") so I can crimp other types of fasteners as well Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
27th Mar 2014 5:49pm |
