![]() | Home > Puma (Tdci) > Cooling system fluid replacement |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Extract from the owners handbook:-
"To make sure that the anti-corrosion properties of the coolant are retained, the antifreeze content should be completely renewed every ten years, regardless of distance traveled". I have used Ford`s coolant to top mine up because I can not purchase the Texaco coolant Land Rover recommend in the handbook. Label on the Ford stuff says it provides protection for 10 years. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
Yes, it is a DIY job and proceed as you have mentioned. Puma 110" SW
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Thanks both driver9 and MK for the information. I'm impressed about the 10y lifespan of the OAT fluid!
