Home > Puma (Tdci) > Cooling system fluid replacement
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
My Defender is 5y old and before summer season I would like to replace the cooling system fluid.
Is this a DIY task that can be made at home ? I read somewhere that fluid can be drained by disconnecting the water lines from the fuel cooler located on the bottom of the vehicle.
The refill must be entirely made from the expansion tank ?
Any advice or suggestion really appreciated, thanking in advance.
Post #317062 19th Mar 2014 5:10am
driver9
Extract from the owners handbook:-
"To make sure that the anti-corrosion properties of the coolant are retained, the antifreeze content should be
completely renewed every ten years, regardless of distance traveled".
I have used Ford`s coolant to top mine up because I can not purchase the Texaco coolant Land Rover recommend in the handbook. Label on the Ford stuff says it provides protection for 10 years.
Post #317073 19th Mar 2014 7:14am
MK
Yes, it is a DIY job and proceed as you have mentioned. Puma 110" SW
Post #317127 19th Mar 2014 10:37am
MD5
Thanks both driver9 and MK for the information. I'm impressed about the 10y lifespan of the OAT fluid!
Post #317287 19th Mar 2014 7:52pm
