Home > Tdi > Matching temp sender and temp gauge
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
As you know i have recently accuired a 90 2.5td fitted with a 200tdi engine by p.o. the temp gauge always tends to stay around the hot area sometimes just before the red and sometimes just inside the red, i know a temp gauge and temp sender should be matched but i have no idea if the engine has a 2.5td sender fitted or a 200tdi sender fitted, is the temp gauge compatable to both sender units or do i need to buy a 200tdi sender and gauge Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #314415 8th Mar 2014 12:44am
dorsetsmith
try Steve Parker website under 200Tdi into 90/110 conversion,
Post #314425 8th Mar 2014 6:27am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I swapped mine over to a VDO gauge - actually gives you a reliable temp, rather than land rovers hottish and coldish gauge.
You can see when the 'stat opens it's that accurate.
Post #314452 8th Mar 2014 10:28am
SGH
I bought matched VDO gauge and sensor from Demon Tweeks for my 300tdi
Post #314453 8th Mar 2014 10:30am
g-mack
i like the look of the vdo vision gauges! would be a nice upgrade for crappy tdi dash!! My 109 thread
my youtube channel
Post #314458 8th Mar 2014 11:52am
ARC99
If I remember rightly the temperature between Normal and Hot is only 2C.
There are two different sender units for that engine, one has a green seal and the other a blue. Don't make old people mad.
Richard
Post #314460 8th Mar 2014 12:04pm
cornish rattler
So will a 200tdi temp sender match the original temp gauge or the 2.5td and 200tdi temp gauges the same Smile Graham
Post #314624 9th Mar 2014 1:04am
ARC99
It hurts when you get old and cannot remember things like yesterday
My 2.5 was built with a 200 temp gauge as were others, I purchased a sender unit for a 2.5, the parts man at my local Indi did not know about the two sender units and gave me a later unit when it should have been and earlier one. Don't make old people mad.
Richard
Post #314678 9th Mar 2014 12:31pm
cornish rattler
Right I see I have already ordered a 200tdi sender from paddocks amongst a few other bits but think I will buy a 200tdi temp gauge aswell rather than keep messing about swapping stuff about as I am not really sure what setup I have as the tdi engine was fitted a few years ago by the last owner and I am not entirely sure what gauge I have as originally the 90 was a 2.5td so think this is the way to go Wink Graham
Post #314686 9th Mar 2014 12:58pm
cornish rattler
I have since found out that 2.5.TD and 200TDIs used the same gauge so I will fit the defender 200tdi sender and see how it goes Smile Graham
Post #316315 15th Mar 2014 11:21pm
cornish rattler
Right I removed my temp sender today to replace it with a new one but when I removed it the sender didn't have a seal on it and the new one didn't either but both look the same, my new one is a defender 200tdi one from paddocks in a blue box Embarassed
does the sender need a seal as I am thinking could the sender be earthing on the cylinder head where it screws into the head Smile Graham
Post #316662 17th Mar 2014 5:55pm
Ant54
Its supposed to earth on the cylinder head Wink
Post #323366 12th Apr 2014 7:10pm
cornish rattler
Cheers for that its just that on series trucks they used to have a fiber washer between the sender and head as its the middle bit that measures the heat and doesn't touch anything to earth out on so I was thinking if there was no washer on a tdi sender it mite earth out when screwed up to the head Confused Graham
Post #323749 14th Apr 2014 8:23pm
