![]() | Home > Tdi > Matching temp sender and temp gauge |
try Steve Parker website under 200Tdi into 90/110 conversion,
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
I swapped mine over to a VDO gauge - actually gives you a reliable temp, rather than land rovers hottish and coldish gauge.
You can see when the 'stat opens it's that accurate. |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I bought matched VDO gauge and sensor from Demon Tweeks for my 300tdi
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
i like the look of the vdo vision gauges! would be a nice upgrade for crappy tdi dash!! My 109 thread
my youtube channel |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
If I remember rightly the temperature between Normal and Hot is only 2C.
There are two different sender units for that engine, one has a green seal and the other a blue. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
So will a 200tdi temp sender match the original temp gauge or the 2.5td and 200tdi temp gauges the same
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
It hurts when you get old and cannot remember things like yesterday
My 2.5 was built with a 200 temp gauge as were others, I purchased a sender unit for a 2.5, the parts man at my local Indi did not know about the two sender units and gave me a later unit when it should have been and earlier one. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Right I see I have already ordered a 200tdi sender from paddocks amongst a few other bits but think I will buy a 200tdi temp gauge aswell rather than keep messing about swapping stuff about as I am not really sure what setup I have as the tdi engine was fitted a few years ago by the last owner and I am not entirely sure what gauge I have as originally the 90 was a 2.5td so think this is the way to go
I have since found out that 2.5.TD and 200TDIs used the same gauge so I will fit the defender 200tdi sender and see how it goes
Right I removed my temp sender today to replace it with a new one but when I removed it the sender didn't have a seal on it and the new one didn't either but both look the same, my new one is a defender 200tdi one from paddocks in a blue box ![]() does the sender need a seal as I am thinking could the sender be earthing on the cylinder head where it screws into the head ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Ant54 Member Since: 23 Mar 2014 Location: Rugeley,staffs Posts: 19 ![]() ![]() |
Its supposed to earth on the cylinder head
Cheers for that its just that on series trucks they used to have a fiber washer between the sender and head as its the middle bit that measures the heat and doesn't touch anything to earth out on so I was thinking if there was no washer on a tdi sender it mite earth out when screwed up to the head
