Home > Maintenance & Modifications > Steering guard fitment
H4mmy90
2013 Defender 90 Puma 2.2 HT Orkney Grey
Fitted a second hand steering guard today to my13 truck. But it doesn't seem to stick out far enough?? You couldn't put a D shackle through the two tow hoopes???
Surly this isn't right?? All the holes lined up and it fitted a piece of cake!!
Any ideas
Post #313786 5th Mar 2014 7:38pm
Cheshire110
Yours looks about an inch too far back. On mine the front of the guard fits just behind the numberplate and the loops are easily accessible.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #313789 5th Mar 2014 7:52pm
H4mmy90
That's what I thought! But all the holes line up spot on!
Has yours got air con?? Does it matter like it does with bumpers?
Post #313790 5th Mar 2014 8:13pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mine even stick out in front of the bumper. Can be it the steering guard took a hit against something or does everything look ok?
For as far as I know if you have zircon, it's mainly the front grill that sticks out a bit more.
Post #313792 5th Mar 2014 8:20pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Mine stick out as well, easy to fit a D shackle to it. Something's not right there! Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #313798 5th Mar 2014 8:37pm
H4mmy90
Everything lines up perfect that's what I don't understand.
I'm confused Confused
Post #313806 5th Mar 2014 8:49pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Could it be that you've got the wrong brackets? Confused
Post #313810 5th Mar 2014 9:00pm
H4mmy90
Just spoke to the chap I got it from he had it fitted to a td5 with a first four tubular bumper and it fitted spot on??
Would that make any difference??
Post #313817 5th Mar 2014 9:11pm
GUM97
I don't think so to be honest! Surely it still fits in the same holes in the chassis!? An engine to TDi for!
Post #313819 5th Mar 2014 9:21pm
H4mmy90
Yep that's what I thought, was so easy to fit can't understand how it's wrong
Post #313820 5th Mar 2014 9:23pm
Cheshire110
I'll post a pic of how mine mount when I'm back at the weekend Cheers, David
Post #313823 5th Mar 2014 9:35pm
leeds
Who's make of steering guard is it?
Was it bought off ebay?
I do not think that the geometry of the front end of the chassis has changed in quite a while.
So two possibilities spring to mind, either you have got an oddball of a front end of a chassis, or someone drop a clanger in cutting out those brackets
AFAIK the majority of steering guard plates sit more or less flush with the front end of the chassis legs. Yours seem to sit to far back.
Brendan
Post #313839 5th Mar 2014 10:32pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Those ramps are really very good and so practical.Where they custom made?
Post #313849 5th Mar 2014 11:32pm
Cheshire110
Yeah I'm afraid they were! And they weigh a tonne! Need 2 people to move each one.
Dead solid though when on them and about 2ft extra clearance which is perfect to crouch under for waxoyling etc Cheers, David
Post #313851 5th Mar 2014 11:35pm
Just don't drive off the side what ever you do. Whistle WeWillWin🇬🇧🇺🇸
Post #313853 5th Mar 2014 11:48pm
