Home > Td5 > Keyfob battery
Laurie
Keyfob battery
My keyfob turns the hazzard lights on when locking but no longer does so when unlocking.
Is this a sign that the battery needs replacing?
I would try the other fob but it's at the bottom of the wife's handbag, so it's quicker to ask on here.
Post #312349 28th Feb 2014 2:07pm
Green Machine
Yes Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #312352 28th Feb 2014 2:23pm
Laurie
Thanks Very Happy
Post #312353 28th Feb 2014 2:27pm
K9F
Laurie,
If you're changing the battery a couple of tips you may be interested in perhaps? Thumbs Up
http://www.defender2.net/forum/topic13844.html?highlight=fob
http://www.defender2.net/forum/topic5654.html?highlight=fob If you go through life with your head in the sand....all people will see is an ar5e!!
Post #312358 28th Feb 2014 2:58pm
Martin 01
Mine has done this for a while.
Just changed the battery as previously said & voila it's working again.
So simple yet so annoying when it wasn't working.
The things people know on here are brilliant.
Easy fix even for me.
Thumbs Up
Post #312362 28th Feb 2014 3:25pm
Laurie
Thanks guys.
Any idea what a MD charges to change it?
Post #312363 28th Feb 2014 3:33pm
landy andy
What battery is required please, as mine is getting low so could do with getting a replacement.
Andy
Post #312370 28th Feb 2014 3:44pm
K9F
Laurie,
It's supposed to be done as part of a two year service I believe. Not sure how much for an individual one off but think it's worth your while doing it yourself. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #312377 28th Feb 2014 3:59pm
Laurie
Service due mid-April. I'll use the wife's keyfob 'til then. Very Happy
Post #312379 28th Feb 2014 4:02pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Laurie, If your wifes handbag is as full of c*ap as my wifes it'll take you to April to find the spare key Rolling with laughter
Post #312385 28th Feb 2014 4:27pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
The keyfob battery is a CR2032. When replacing it just make sure you've unlocked the car & had the ignition on to position II before turning it off & splitting the two halves of the fob. Remove dead battery then press either button to drain residual power from circuits, then replace the battery (don't touch the battery if possible, but don't use metal tweezers either...) When you fit the two halves back together, press the lock button 4 times the the unlock button once to re-sync it with the alarm ECU. Job Done. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #312393 28th Feb 2014 5:39pm
Laurie
........your time starts NOW! Rolling Eyes
Post #312397 28th Feb 2014 6:02pm
Martin 01
Laurie,
Dead easy job if you do it as described above. Thumbs Up
Just done mine, only 5 min job.
Great info
Post #312404 28th Feb 2014 6:14pm
Laurie
Thanks. I'll give it a go. Very Happy
Post #312413 28th Feb 2014 6:26pm
Laurie
Took the Defender in to get the wipers fixed today.
Asked them to change the keyfob battery while they were at it.
Robert took the fob to the back of the garage where the batteries were stored, slipped the old one out, put a fresh one in and went back to the Defender. Works perfectly. Why all the supposed 'Masonic' ritual? Confused
Post #314344 7th Mar 2014 6:33pm
