Home > Td5 > Keyfob battery |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Yes 2005 Td5 | 90 Station Wagon | Tonga Green
28th Feb 2014 2:23pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Thanks
28th Feb 2014 2:27pm |
Laurie,
If you're changing the battery a couple of tips you may be interested in perhaps? http://www.defender2.net/forum/topic13844.html?highlight=fob http://www.defender2.net/forum/topic5654.html?highlight=fob If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Feb 2014 2:58pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
Mine has done this for a while.
Just changed the battery as previously said & voila it's working again. So simple yet so annoying when it wasn't working. The things people know on here are brilliant. Easy fix even for me. |
28th Feb 2014 3:25pm |
Thanks guys.
Any idea what a MD charges to change it? |
28th Feb 2014 3:33pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5720 |
What battery is required please, as mine is getting low so could do with getting a replacement.
Andy |
28th Feb 2014 3:44pm |
Laurie,
It's supposed to be done as part of a two year service I believe. Not sure how much for an individual one off but think it's worth your while doing it yourself. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 28th Feb 2014 6:00pm. Edited 1 time in total |
28th Feb 2014 3:59pm |
Service due mid-April. I'll use the wife's keyfob 'til then.
28th Feb 2014 4:02pm |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
Laurie, If your wifes handbag is as full of c*ap as my wifes it'll take you to April to find the spare key
28th Feb 2014 4:27pm |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 |
The keyfob battery is a CR2032. When replacing it just make sure you've unlocked the car & had the ignition on to position II before turning it off & splitting the two halves of the fob. Remove dead battery then press either button to drain residual power from circuits, then replace the battery (don't touch the battery if possible, but don't use metal tweezers either...) When you fit the two halves back together, press the lock button 4 times the the unlock button once to re-sync it with the alarm ECU. Job Done. Mark S
CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
28th Feb 2014 5:39pm |
........your time starts NOW!
28th Feb 2014 6:02pm |
Laurie, Dead easy job if you do it as described above. Just done mine, only 5 min job. Great info |
28th Feb 2014 6:14pm |
Thanks. I'll give it a go.
28th Feb 2014 6:26pm |
Took the Defender in to get the wipers fixed today.
Asked them to change the keyfob battery while they were at it. Robert took the fob to the back of the garage where the batteries were stored, slipped the old one out, put a fresh one in and went back to the Defender. Works perfectly. Why all the supposed 'Masonic' ritual? |
7th Mar 2014 6:33pm |
