![]() | Home > Td5 > TD5 Sluggish |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
I'm not aware of any difference between a 90 and 110 ECU. Have you checked all the usual things to make sure the engine is behaving? www.td5.org
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Is it possible you had a remap on your previous ecu? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Ruari Member Since: 10 Dec 2013 Location: Ayrshire Posts: 50 ![]() ![]() |
I plugged in the Hawkeye this morning. Mas Air flow logged.
I got a spare to give it a try, |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I think there is some torque differences between the 90 & 110 tune, but nothing that you'd really notice.
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
just disconnect it to try ... Postmanpat |
Stoo Member Since: 20 Aug 2009 Location: Maidstone, Kent Posts: 37 ![]() ![]() |
Like others have said; check the MAF by disconnecting and see if performance improves.
If so - replace - but only with genuine/OEM as the cheap ones last no time at all really. Stoo ![]() ![]() Last edited by Stoo on 28th Feb 2014 2:10pm. Edited 1 time in total |
" but only with genuine/OEM as the cheap ones last not time " +1 ... Postmanpat
No difference unplugging it. I got a spare in the big box of bits anyway.
Can I fit any TD5 defender (not disco) ecu into my car, code injectors & security and it will be ok? Or are the numbers very important? |
if you unplugged it and it made no difference its fine . re ECU not to sure Postmanpat
