Home > Td5 > TD5 Sluggish
Ruari
2000 Defender 110 Td5 HT Alpine White
TD5 Sluggish
After all my trouble when the TD5 died due to Ecu.
I now notice that when towing (a discovery 1995) that my car is quite sluggish compared to previously.
Is there a big difference is the set up of the 90 & 110 ecu?
Post #311202 24th Feb 2014 10:25am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I'm not aware of any difference between a 90 and 110 ECU. Have you checked all the usual things to make sure the engine is behaving? www.td5.org
Post #311212 24th Feb 2014 10:49am
adseybear
Canada
Is it possible you had a remap on your previous ecu? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #311561 25th Feb 2014 6:08pm
Ruari
I plugged in the Hawkeye this morning. Mas Air flow logged.
I got a spare to give it a try,
Post #311838 26th Feb 2014 10:48am
I think there is some torque differences between the 90 & 110 tune, but nothing that you'd really notice.
Post #311852 26th Feb 2014 12:09pm
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
just disconnect it to try ... Postmanpat
Post #312322 28th Feb 2014 12:48pm
Stoo
2005 Defender 90 Td5 XS CSW Bonatti Grey
Like others have said; check the MAF by disconnecting and see if performance improves.
If so - replace - but only with genuine/OEM as the cheap ones last no time at all really.
Stoo
Mr. Green Mr. Green
Post #312345 28th Feb 2014 1:46pm
Postmanpat
" but only with genuine/OEM as the cheap ones last not time " +1 ... Postmanpat
Post #312346 28th Feb 2014 1:55pm
Ruari
No difference unplugging it. I got a spare in the big box of bits anyway.
Can I fit any TD5 defender (not disco) ecu into my car, code injectors & security and it will be ok? Or are the numbers very important?
Post #313087 3rd Mar 2014 12:08pm
Postmanpat
if you unplugged it and it made no difference its fine . re ECU not to sure Postmanpat
Post #313113 3rd Mar 2014 2:04pm
