![]() | Home > Maintenance & Modifications > door card removal |
Hi
I need to remove the door cards on my double cab and wanted to know if anybody has diagrams/hints on how to do it without breaking to many of the clips holding them on. Also, is there a trim removal tool that makes life easier ? I originally thought that I would just buy a complete new set of clips for each door until I found out there are 24 clips per door and they cost 69p each plus VAT ![]() Ta Bob |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Hi Bob i could do with this diagram as well i think its been asked for before... there is a tool for this, i think there only cheap , Also heres a link for door card clips,
http://cgi.ebay.co.uk/Land-Rover-Defender-...1e5a11311e NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
I saw those clips but the chassis number range looks like it is only for TD5's.
I was going to wait until the genuine LR ones arrive this week and then compare them to see if they are the same. Bob |
Will do Karl.
I found some others on ebay and, I must admit, they do all look the same. I might pester my dealer to see if there is a diagram detailing the card removal. Bob |
I'm in the dealers tomorrow I'll ask as well see what they say
Exactly what I am going to do on Wednesday when I pick my clips up
![]() Bob |
Hi Bob went to dealer today asked for door card removal information and all they had on there computer was this...He explained a little how to get it off but not really any help he said you will probably damage the push in door card clips but its a simple job
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
jools Member Since: 23 Feb 2010 Location: Devon Posts: 47 ![]() ![]() ![]() |
I took the rear door card off at the weekend - to tighten up the door lock mechanism that was loose (even though it had a pre-delivery check
![]() It was on fairly firmly - I just popped it off from the hinge side using a screwdriver (no special tool!) None of the fixings broke - so once i'd finished with the lock just lined it up and popped it back on Job done! Jools 2003 90 XS SW Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4 |
Karl Just picked up my clips and they look exactly like the ones on flea bay but mine cost 69p each ![]() Any idea where your pictures went ??? My dealer said there were no tricks to removing the door cards - just keep your fingers crossed that you don't break all the clips ! Bob |
Hi Bob pics back, They told me the same thing no tricks You can see in the pics where the clips go it may help
Thanks Karl - at least I know where to locate the broken bits now
![]() Bob |
Bob this is the tool you need or a screwdriver
![]() http://cgi.ebay.co.uk/DOOR-CARD-TRIM-UPHOL...f0ffd8f0a5 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Thanks Karl.
I will get one on order ![]() Bob |
