![]() | Home > Maintenance & Modifications > Fitting Winch to 90 with A/C |
dshickle Member Since: 09 Oct 2007 Location: Epsom Posts: 36 ![]() ![]() |
Hi mse,
If you get a winch bumper designed for A/C verhicles you won;t need to cut the grill. I got mine from here You can get one from Mantec - who are providers to LR for much of the kit LR sell. It is a very simple task fitting your own winch, just make sure you fit a cut-out switch inside the defender - mine is installed at the bottom of the passenger seat near by the battery. David Disovery 3 TDV6 SE Defender 90 XS 2.4 Defender 110 S D250 (MY22) |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Thanks
I did have a cut out switch already set up on my last one - will get the warn version which offers a smaller switch to control a solenoid. My big concern on bumper was the type approval i was told is now required for 07 vehicles...and land rover bumpers being type approved. Does anyoone know if they are the full bumper or the central tray insert Mike |
