![]() | Home > Puma (Tdci) > Finally had enough |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
322tpe, It will be the plastic selector on top of the gearbox that as worn...You need a new one....I ended up getting a new gearbox as the plastic selector was out of stock, keep on at them as it should not be like that, don't take no for an answer, Tell them you want to test drive a new one and to get their technician to test drive yours with you in it and see the difference NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
322tpe Member Since: 06 Jan 2009 Location: England Posts: 16 ![]() |
Fekete
Thanks for that at least its put my mind to at least getting it back quickly It doesn't help when the dealers are in complete denial about the clutch/box problems.Even on the test drives they deny there any problems and when you push it you get the impression that its a taboo subject."No,never had any back in with this problem" is the rehearsed speech when I know for a fact theres three others that I know of that have got the same problem Its just like the Fawlty Towers sketch about the german tourists only in this case its "I mentioned the clutch but I think I got away with it " ![]() Woeful product design and a shambolic attempt to cover it up ![]() Last edited by 322tpe on 26th Feb 2010 4:11pm. Edited 1 time in total |
It took me 6 or 7 attempts same sh!t off the dealer...they even told me at one point well it is tractor like...Don't except their Sh!t...Get their technician to test drive it with you in it...I've found that if your persistent they will give in in the end..Hope you get it sorted. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
I started to have the same issue about 4 weeks ago, took it into my local LR service centre (thankfully its not a dealership) and they diagnosed the selectors needed replacing..
bad news was that they were on back order, have been waiting since then for them to come in. Thankfully ive been away lots so not really an issue, popped in to see them this morning and theyve ordered me a new gearbox that will be getting fitted next week ![]() |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
If i change between 1st and 2nd to fast i get a clunck is that the same problem ?
my problem is between 1st, 2nd & 3rd when trying to select the gear it feels like youre fighting against it.
Almost as if the clutch isnt fully depressed, so it clunks into gear Its even worse in low range. Puma 2.2 90 Stationwagon |
Yeah mine does that if i have to change gear quick might see what they say at my dealer then |
Paul get it in and get it logged then you have highlighted the problem to LR in case it get worse
its going in on Monday to try and sort the fuel consumption so I'll mention it and see what they say.
Paul just tell them your not happy with it.... get a technician to test drive it with you in it
yeah mate i wont stand any messing I'll take my crutches and point them at every one
just had a thought (sorry to stamp on the thread) if your landy is on finance like mine is would the finance company add any weight to any complaint's you make to a dealer ?
Paul not too sure I'd thought the contract was with you and not LR...some one will correct me if i'm wrong NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Hans Member Since: 12 Jan 2010 Location: Lot, France Posts: 45 ![]() ![]() ![]() |
When approaching a red traffic light, driving slowly, I put the gearbox in neutral and lift my foot off the clutch pedal I hear a loud knocking noise under the car as if some part is loose and banging around. My dealer told me this is normal with Defenders.
I think this is rubbish. Should I take it back to the dealer? Hans http://www.orlaya.fr |
