![]() | Home > In Car Electronics > Alpine Head Unit. |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
You didn't install the mic near an air vent or anything did you? 1998 110 300Tdi White Hard Top
Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675 ![]() ![]() ![]() |
Nope, it was stuck on the steering column...
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
On my 13 I always find when someone rings me , I have to select it on the phone before they can hear me.
Dialling out auto picks up |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
I have my mic at the top of the a pillar on the drivers side. But it is Kenwood so actually works! (Takes cover!)
It seems iPhones and most in car BT system often get sone issue or other at some point. Most are easily solved though with a simple fiddle of a few settings. Might be worth doing a sound check though, give someone a call as a test if they are willing. Ignition on no air vents going so silence, see how it sounds then. If it still sounds quiet there's a mic sound pick up issue, if it sounds better it's the positioning that's causing the problem. If none of that works out then there is small chance there might actually be a problem with the mic it's self. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ Last edited by custom90 on 30th Jan 2014 9:48pm. Edited 2 times in total |
Tried it again and I was shouting that loud they could hear me in the house...Who needs a mic...
Spent an hour this morning with the instructions and still can't get the mic to work...
Has anyone got any ideas.. Cheers... |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Pull the head unit out of the dash and make sure the mic is physically plugged into the back of the head unit.
It was close to getting pulled out and slung across the carpark...
Dont do that, its a cracking stereo.
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
If its an incoming call not outgoing that has the problems, have you tried to answer the incoming on the head unit its self and not on the phone ?
In sone cases if you answer from the phone and not the head unit the mike used is the phone mike and not the external one, which means while in the call in some cars you have to manually select the car before the caller can here you. I think this is aimed at you not having or supposed to touch your phone while driving and so control is done via the head unit and not the phone buttons. Pete Last edited by bell-auto-services on 2nd Feb 2014 11:33pm. Edited 2 times in total |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Yep my phone give me this option, answer the call on the phone and you have use the phone for the call. Answer the call with the head unit and the Bluetooth takes the call.
Incoming and outgoing, the mic wont work. Adjusted the gain on the mic and bounced between phone / speaker / HU while on a call. Pha!!! I'll see if it's not been plugged in...
