Home > My Defender > clutch pedal down |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Er,whut?lol. Pov.spec,ftw. 2006, 110,TD5.
24th Jan 2014 6:05pm |
You say you changed the engine, but did you change anything relating to the clutch?
24th Jan 2014 6:18pm |
chopperpk Member Since: 14 May 2012 Location: sunderland Posts: 32 |
Everything cycle
24th Jan 2014 6:19pm |
Yes every thing cycle
24th Jan 2014 6:22pm |
Master cylinder, slave cylinder, flexible hose, clutch fork, and re bled the system?
24th Jan 2014 6:23pm |
Yes oral new cycle
24th Jan 2014 6:25pm |
Brand new parts or off the donor 200tdi?
24th Jan 2014 6:28pm |
New cycle
24th Jan 2014 6:29pm |
Just re-read your first post, does the clutch work fine? If it's just the height of the pedal is too low (but still works) you can adjust the height of the pedal in the top of the clutch pedal box.
24th Jan 2014 6:36pm |
Changes gear.just pedal height cycle
24th Jan 2014 6:42pm |
You can adjust the pedal height wth the linkage on the end of the master cylinder. You might be best getting a Haynes manual as it will show you pics of the exact bit to adjust
24th Jan 2014 6:55pm |
