Home > My Defender > clutch pedal down
chopperpk
England 2013 Defender 90 Puma 2.2 HT Tamar Blue
clutch pedal down
I have a 1992 defender n/a.when I got it the clutch pedal was right down.could change gear.put a 200tdi in.put orl new clutch related things.clutch pedal still write down still.enemy I dear cycle
Post #301821 24th Jan 2014 6:50pm
jimbob7
Er,whut?lol. Pov.spec,ftw. 2006, 110,TD5.
Post #301823 24th Jan 2014 7:05pm
mk1collector
You say you changed the engine, but did you change anything relating to the clutch?
Post #301828 24th Jan 2014 7:18pm
chopperpk
Everything cycle
Post #301830 24th Jan 2014 7:19pm
chopperpk
Yes every thing cycle
Post #301832 24th Jan 2014 7:22pm
mk1collector
Master cylinder, slave cylinder, flexible hose, clutch fork, and re bled the system?
Post #301833 24th Jan 2014 7:23pm
chopperpk
Yes oral new cycle
Post #301836 24th Jan 2014 7:25pm
mk1collector
Brand new parts or off the donor 200tdi?
Post #301837 24th Jan 2014 7:28pm
chopperpk
New cycle
Post #301838 24th Jan 2014 7:29pm
mk1collector
Just re-read your first post, does the clutch work fine? If it's just the height of the pedal is too low (but still works) you can adjust the height of the pedal in the top of the clutch pedal box.
Post #301841 24th Jan 2014 7:36pm
chopperpk
Changes gear.just pedal height cycle
Post #301843 24th Jan 2014 7:42pm
mk1collector
You can adjust the pedal height wth the linkage on the end of the master cylinder. You might be best getting a Haynes manual as it will show you pics of the exact bit to adjust
Post #301849 24th Jan 2014 7:55pm
