Home > Technical > discovery v8 engine and box into a 90
maxi333
1989 Defender 90 V8 Petrol HT Alpine White
hi guys im new to this forum. i have just bought a f reg 90 and i am planning on putting a v8 engine from a discovery with the discovery transfer box and gear box. i was just wondering if the gear stick will be in the wrong place. any suggestions to my problem.
cheers max
Post #24571 17th Feb 2010 8:42pm
jst
manual i take it with ref to the gear stick and an auto is cable actuated so you can put it anywhere.
you will find the bell housing is longer on the Disco unit meaning the gearstick will be further back, you can get around it by using a Def bell housing, or put the V8 to a Def gearbox or an auto!
i wouldn't go bigger than 235/85s with a 1.2 t box on a 90 even with a V8!! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #24577 17th Feb 2010 9:06pm
maxi333
great thanks for your reply. what diesel gear box would i need to fit a v8 using an adapter plate.
thanks
Post #24579 17th Feb 2010 9:12pm
jst
i dont know.
my experience is either V8s and LT85s as per std LR fit or V8s and Autos or diesels and autos into 90s.
would a std def lt77 short bellhousing not go onto a disco v8 if an adapator ring was used (if needed?) to connect the flywheel housing to bellhousing? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #24602 18th Feb 2010 10:23am
Martin
Site Admin
Site sponsor Ashcroft Transmissions will help you with gearbox queries Thumbs Up
Post #24603 18th Feb 2010 10:46am
