Home > Technical > discovery v8 engine and box into a 90 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
manual i take it with ref to the gear stick and an auto is cable actuated so you can put it anywhere.
you will find the bell housing is longer on the Disco unit meaning the gearstick will be further back, you can get around it by using a Def bell housing, or put the V8 to a Def gearbox or an auto! i wouldn't go bigger than 235/85s with a 1.2 t box on a 90 even with a V8!! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
17th Feb 2010 9:06pm |
maxi333 Member Since: 17 Feb 2010 Location: wales Posts: 2 |
great thanks for your reply. what diesel gear box would i need to fit a v8 using an adapter plate.
thanks |
17th Feb 2010 9:12pm |
i dont know.
my experience is either V8s and LT85s as per std LR fit or V8s and Autos or diesels and autos into 90s. would a std def lt77 short bellhousing not go onto a disco v8 if an adapator ring was used (if needed?) to connect the flywheel housing to bellhousing? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
18th Feb 2010 10:23am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
Site sponsor Ashcroft Transmissions will help you with gearbox queries
18th Feb 2010 10:46am |
