Home > Puma (Tdci) > Home Service |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
There's a small bolt holding the panel over the fuel filter, the filter just unscrews like on the Td5.
The oil filter cover nut is conveniently the same size as a wheel nut so you can guess what's easy to use there. Don't know what oils you have over there, here I use Castrol Edge 0W-40. Don't forget to grease the uni-joints. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
16th Feb 2010 9:20pm |
