Home > Puma (Tdci) > Home Service
mhill
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Bonatti Grey
Home Service
Its coming up to 9K but the oil is utterly filthy and in need of a service, im fairly competent tinkering with spanners and screw drivers so going to do the first one DIY.
Oil change & filters look easy enough to do but not sure on the fuel filter is deceiving me (i guess im being a blind fool) i guess a guide if such a item existed would be handy if anyone has one?
Secondly, which oils is recommended?
Thirdly, whats the best place for service kits?
Many Thanks
Miles
Post #24476 16th Feb 2010 8:13pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
There's a small bolt holding the panel over the fuel filter, the filter just unscrews like on the Td5.
The oil filter cover nut is conveniently the same size as a wheel nut so you can guess what's easy to use there.
Don't know what oils you have over there, here I use Castrol Edge 0W-40.
Don't forget to grease the uni-joints. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #24483 16th Feb 2010 9:20pm
