Home > Tdi > 300tdi choices must be made soon, please help
300 tdi
90
50%
 50%  [9]
110
50%
 50%  [9]
Total Votes: 18
Page 2 of 2 <12
diseasel
maybe the old boy was getting confused with the v8 one he had, any road, I do believe I have made a decision on a 90 van conversion 300.. Because its registered commercial, is there any way of changing that to match a csw (insurance wise i have had csw's appear as cars not vans)
I am also looking into buying a semi reasonable one and refurbing it, any engine suppliers and interior trimmers that aren't exmoor, bearing in mind i'm not a keen fan of the bucket seats and microwheel.
best accessory shops?
and one last one is, where can i find those metal eyelets people use on the body to reroute the exhaust out the side of the shell?
Thanks very much for all your help, advice and knowledge ladies and gents, its much appreciated
Stay muddy Thumbs Up
Post #300473 20th Jan 2014 1:59am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Changing to csw has become quite an ordeal due to the lez inside the m25. Too many people were trying and dvla now basically go off the chassis number, if it was born as a van it stays one. That is not to say that insurance won't be understanding but it is not as simple as it was. Rhubarb and custard let fly with their secret weapon.
Post #300479 20th Jan 2014 5:15am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Mine was converted before I got it, no problems with insurance as long as you go to someone like Flux or Lancaster, it is only main stream insurers who are more picky.
I find Mailorder 4x4 very good, its just nobody is cheapest for everything, 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #300487 20th Jan 2014 7:08am
diseasel
cheap isn't such a problem if its good stuff, im looking for the most variety really
Post #300833 21st Jan 2014 12:00pm
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
'I had a look at a 300 90 van, I see the panel supports in the back, are they glued and bolted or riveted?'
I've recently done a van to sw conversion - pretty easy really, the panel supports are riveted and glued, just drill rivets heads off (8mm drill bit if I remember), then knock off with a hammer. Then its just a jigsaw (aluminium cutting blade), a steady hand and take a deep breath!! Can post a few piccies up if you like.... 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #300836 21st Jan 2014 12:09pm
diseasel
yes please! pictures would be great, do you have any of the seat mounting and belt anchor placement?
Post #301685 24th Jan 2014 12:55am
Page 2 of 2 <12
