![]() | Home > Tdi > 300tdi choices must be made soon, please help |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Changing to csw has become quite an ordeal due to the lez inside the m25. Too many people were trying and dvla now basically go off the chassis number, if it was born as a van it stays one. That is not to say that insurance won't be understanding but it is not as simple as it was. Rhubarb and custard let fly with their secret weapon.
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Mine was converted before I got it, no problems with insurance as long as you go to someone like Flux or Lancaster, it is only main stream insurers who are more picky.
I find Mailorder 4x4 very good, its just nobody is cheapest for everything, 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
diseasel Member Since: 15 Jan 2014 Location: hampshire Posts: 6 ![]() ![]() |
cheap isn't such a problem if its good stuff, im looking for the most variety really
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 ![]() ![]() ![]() |
'I had a look at a 300 90 van, I see the panel supports in the back, are they glued and bolted or riveted?'
I've recently done a van to sw conversion - pretty easy really, the panel supports are riveted and glued, just drill rivets heads off (8mm drill bit if I remember), then knock off with a hammer. Then its just a jigsaw (aluminium cutting blade), a steady hand and take a deep breath!! Can post a few piccies up if you like.... 1959 Series 2 Ragtop 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
yes please! pictures would be great, do you have any of the seat mounting and belt anchor placement?
