Home > Maintenance & Modifications > intercooler install - none air con front but the car has it?
Page 2 of 2 <12
munch90
this can be the trouble when it's aftermarket air con .. we have same problem with ambulances they have it fitted afterwards front and rear and it's a pain to get bits .
Post #297067 8th Jan 2014 10:47pm
Porny
Site Sponsor
I've fitted intercoolers to Td5's with the same setup in the past without a problem.
My IRB/PWR intercooler will fit Whistle
Mainly due the fact is uses a very high quality core - so no need to go so big... which also provides other benefits.
Ian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #297087 8th Jan 2014 11:35pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I needed a new and upgraded intercooler for my Td5 - couldn't get off the shelf due to having both air con and the additional complication of the autobox oil cooler. Got a custom fit one from Allisport for £460. Still needed a couple of mods to get it to fit right though!
However was worth the effort as the difference was obvious as soon as we went off for the first test drive - much smoother and noticely more power. Thumbs Up Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #297126 9th Jan 2014 1:34am
geobloke
Such as?
Post #297223 9th Jan 2014 6:20pm
Porny
Site Sponsor
By using a more efficient core (i.e. not some cheap Chinese made one) you can make the intercooler smaller without loosing efficiency...
The smaller the intercooler, the less volume - which when done properly makes a big difference to drive-ability and response.
Ian IRB
Post #297448 10th Jan 2014 10:53am
geobloke
Thank you Ian. I presume that by also being smaller in overall dimensions, when compared to other "full-size" intercoolers, the unimpeded air flow through the radiator is another advantageous benefit?
Post #297463 10th Jan 2014 11:37am
Porny
Site Sponsor
Yes...
I also do a different radiator with different pitching top and bottom to make more use of the space that is not behind the intercooler... and one that uses the same pitch to get maximum air flow when a larger intercooler is used (needed for some markets and applications)
Ian IRB
Post #297473 10th Jan 2014 11:59am
Page 2 of 2 <12
