Home > Maintenance & Modifications > Joining 3 electrical cables - properly?
Page 2 of 3 <123>
K9F
I would use these with the appropriate Raychem pliers also available from RS. Low profile and hermetically sealed with the heatshrink sleeve that has resin at each end which melts when shrunk sealing the splice.
http://uk.rs-online.com/web/p/crimp-butt-s...s/4445687/
I am also a great advocator of Wago, they do make excellent quality cable termination solutions, however the one depicted is not so environmentally protected. I have used lots of Wago on my Defender but encased it within a high IP rated enclosure.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #297072 8th Jan 2014 9:58pm
Eduardo
Good alternative
Not available in Chile, but I can bring it from USA.
Thanks for the idea.
Cheers! Eduardo
Post #297129 9th Jan 2014 1:49am
ZeDefender
Thanks again for all the advice - so many ways to kill a cat...
My final solution was soldering with a storm lighter/mini-torch my colleague has lent me (never thought I'd be glad he smokes). As variously suggested, wires were spliced, tied around with copper strands and had a shed load of solder melted into them with a blue flame. Filed it all tidy afterwards. It actually isn't as crap as I was expecting:
Tatra - good points all (pity I only read them after I did the job) - however, I will make sure the joint is fixed to something to prevent breakage.
Mal - nice solution. You always find the obscure stuff. I was also going to encase any mechanical connection - with butyl tape (also IP-67, I suspect).
Now I just have to wait for the glue-shrink to arrive off the bay :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #297200 9th Jan 2014 2:54pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
When you use the glue heat shrink, as it's starting to shrink and the glue is melting, slightly separate the two wires and using a pair of needle nose pliers crimp the heat-shrink between the two wires.
Leave the pliers there for about 30 seconds until the glue has set. This will give you a better waterproof joint. Again don't forget to rough up the insulation a bit with some emery cloth.
Post #297225 9th Jan 2014 5:21pm
ZeDefender
Thumbs Up Tell someone you love them today because life is short.
Post #297243 9th Jan 2014 6:51pm
K9F
Very Happy It's not so much 'obscure stuff' but on the 85 metre high-speed catamarans I work on with regards to environment from an electrical perspective it's probably the harshest it gets. The fact the vessels are aluminium they sweat due to rapid temperature changes, add seawater, oil etc into the mix and you can perhaps see what I mean. Through trial and error we use what is best as it saves the inevitable revisit to the same job over and over again. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #297317 9th Jan 2014 8:44pm
Appreciate the job is done now but for others there is also these as an option:
http://www.posi-lock.com/index.html
Post #297333 9th Jan 2014 9:22pm
martinfiattech
If you want a really quick and cheap soildering iron get an old glow plug and use that. Just don't use the vehicles battery to power it as a large spark is usually a surprise,. and be on the safe side disconnect the vehicle earth. Its got me out of trouble more than a few times on brake downs Very Happy
Post #297935 11th Jan 2014 9:04pm
ZeDefender
Shocked How exactly do you use that? Tell someone you love them today because life is short.
Post #297940 11th Jan 2014 9:09pm
martinfiattech
Easy hot end of glow plug is red hot 650`c if that wont melt soilder its blow torch time. Just don't leave the glow plug on to long in one go, they do get a bit warm Very Happy
Post #297948 11th Jan 2014 9:20pm
ZeDefender
Time to get tinkering then Mr. Green
Just a standard deffy plug (TD5, Puma?) with a 12v battery or will any plug do? Tell someone you love them today because life is short.
Post #297972 11th Jan 2014 10:42pm
ericvv
Learning something here again. Interesting comments about Wago connectors which I did not know. Would you use these in below link on a Defender for electric connections provided that there is space available? 3-way and 2-way.
http://www.amazon.de/gp/product/B00D8XYPPC...N4GVFW0T0K
http://www.amazon.de/gp/product/B00C26L2R0...N4GVFW0T0K
If not, which other type Wago then?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #297996 12th Jan 2014 6:55am
ZeDefender
These were my originally favoured mechanical alternative (i.e. first one that came up on eBay Whistle ).
A few things that I would take care of though:
1) are they original Wago and not cheap fakes? It seems impossible to get the real deal (e.g. Superseal) these days Sad
2) How much surface area of the wire is in contact with the connector? Would voltage/current etc. be a problem?
3) How easy is it to waterproof them/would they deteriorate over time e.g. due to bimetallic corrosion?
4) To deal with 3) how large/expensive would an (or multiple) IP6something enclosure(s) be?
5) How mechanically stable are they? Tell someone you love them today because life is short.
Post #298003 12th Jan 2014 7:47am
landy andy
I wouldn't use them in an exposed environment as a permanent solution.
Have seen this sort of connector used and fail in domestic use (house wiring) so it's no from me.
Andy
Post #298008 12th Jan 2014 7:55am
VeeTee
Netherlands
To add to that:
Wago has different types of these connectors, for massiv or stranded cable. Because for automotive applications you always use stranded wires, make sure you use the right type. There is a lot of info on the Wago website.
I think they are very capable and usefull, if they are well installed, i.e. with good fixing of cables and connectors on a firm surface or in a proper enclosure. Cheers, Vincent
MySite
Post #298012 12th Jan 2014 8:16am
Page 2 of 3 <123>
