Home > Maintenance & Modifications > Dixon Bate Ball & Pin Tow Thingies
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Are the pins strong enough for (normal) recovery?
Question
Post #23935 9th Feb 2010 7:07pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
It should have a rating, some are as low as 1.5t alot are 3t and you can get 5t. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #23938 9th Feb 2010 7:22pm
Chunk
Looking at the 3.5t rated ones, the 5t ones are a bit spendy for what they are.
Post #23943 9th Feb 2010 7:46pm
Glynparry25
Does what it says on the box. It will take 3.5 ton of strain- but remember i has to be bolted to something that will also take it- not like people who bolt a 5 ton jaw to the rear cross member and then get confused when the cross member bends under 3 ton of strain.
Dixon Bate is a good name and they do deliver quality
Gyn
Post #23953 9th Feb 2010 8:51pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
On the Camel Trophy Discovery's were 2 of the 3.5 tons on the front and a 5 Ton at the back.
In my experience the 3.5 tons are strong enough. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #23975 10th Feb 2010 7:38am
K9F
Recovery Points.
Willy Eckerslike got me thinking with his throw away comment of "Where's your recovery points Ciderboy?" sometime ago. On reflection it was a good point and very well presented! However I didn't really deem them as necessary at that time. I am envious of the fun those who went to the Peak District had, and when I do eventually go to a meet wish to be somewhat prepared allbeit minimally to begin with.
Somewhere on this site and I'm bu993red if I can find it now a member has a photograph of two of the Dixon Bate Ball and Pins mounted to his front bumper.
My question is thus;- is the bumper up to the task of having these mounted for recovery purposes only. Unfortunately the style of steering guard I have precludes me from mounting recovery rings to the chassis.
Any other serious options/suggestions would be appreciated.
Not Dixon Bates' but can I assume from this that bumper recovery points are indeed ok?
Ta muchly! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #24817 22nd Feb 2010 8:56am
Glynparry25
If you have fitted a beefy bumper then yes it will be strong enough- normal LR unit isn't. If you want to stay standard though something like the Millitary bumper with the recovery pin in the middle is a good idea. I went for Dixon Bate jaws on a MANTEC bumper.
Glyn
Post #24852 22nd Feb 2010 3:36pm
