Home > Puma (Tdci) > URGENT HELP! OIL IN COOLANT HEADER RESERVOIR
dkwillo
United Kingdom 1996 Defender 110 300 Tdi CSW Alpine White
Dear Forum
I have a fleet of Defender Puma Tdci 2012 2.2 litre vehicles. One has just arrived in the workshop with a report of the temperature gauge not working. On inspection there was A LOT of oil in the coolant reservoir and there was minimum oil level when inspecting the oil dipstick.
There seems to be oil spread throughout the coolant system when we checked the coolant pipes. Has anyone experienced this before?? The cylinder head gasket seems to be intact. It was suggested we check the oil cooler for a crack which would allow the oil to mix with the water.
Any help or suggestions would be really appreciated.
Cheers 1996 Station wagon 300tdi
2000 110 Pick up 300 tdi
Post #295437 3rd Jan 2014 1:44pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Oil cooler. Oil system runs at higher pressure than coolant system, thus oil contamination of coolant system NOT vica versa. Thumbs Up
Oil temperature higher than coolant thus temperature gauge shows higher temperature as it is reading oil not coolant temperature. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #295451 3rd Jan 2014 2:34pm
frogface65
United Kingdom 2012 Defender 110 Puma 2.2 USW Alpine White
hi
yes had same ,
see link
http://www.defender2.net/forum/topic15480.html
Went back to dealer for a flush out and replacement of oil cooler that failed i think .told this<When ford supplied the engines there was spew in the cooling system .
LOT OF MESS
Keep an eye on your paintwork as mine started to craze , got respray , not sure what they used to flush the pipe out with ...
Post #297861 11th Jan 2014 6:44pm
vulcanfreak
2006 Defender 90 Td5 Silver LE Zambezi Silver
Has anyone `not familiar` with engine layout checked oil and topped up the incorrect filler ? I have seen it happen !
Post #298039 12th Jan 2014 10:15am
RED-DOT
Truck dealers use liquid washing cleaner like Persil or liquid Fairy in water. For a Defender i would use 250ml three times or untill the water is clean then flush out and add anti-freeze. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #298646 14th Jan 2014 11:00am
landy andy
I have used fairy, persil washing LIQUID, (not powder) to clean water system and it works well. Just keep doing it until clear.
Andy
Post #298779 14th Jan 2014 6:49pm
RED-DOT
Fairy froths up and can cause overheating.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #298808 14th Jan 2014 7:41pm
landy andy
I'm talking about washing liquid for clothes, just to be clear not the stuff for plates etc.
Post #298814 14th Jan 2014 7:50pm
