![]() | Home > Puma (Tdci) > URGENT HELP! OIL IN COOLANT HEADER RESERVOIR |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Oil cooler. Oil system runs at higher pressure than coolant system, thus oil contamination of coolant system NOT vica versa.
![]() Oil temperature higher than coolant thus temperature gauge shows higher temperature as it is reading oil not coolant temperature. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
frogface65 Member Since: 25 Dec 2013 Location: kent Posts: 5 ![]() ![]() ![]() |
hi
yes had same , see link http://www.defender2.net/forum/topic15480.html Went back to dealer for a flush out and replacement of oil cooler that failed i think .told this<When ford supplied the engines there was spew in the cooling system . LOT OF MESS Keep an eye on your paintwork as mine started to craze , got respray , not sure what they used to flush the pipe out with ... |
vulcanfreak Member Since: 05 Sep 2010 Location: suffolk Posts: 77 ![]() ![]() |
Has anyone `not familiar` with engine layout checked oil and topped up the incorrect filler ? I have seen it happen !
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Truck dealers use liquid washing cleaner like Persil or liquid Fairy in water. For a Defender i would use 250ml three times or untill the water is clean then flush out and add anti-freeze. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
I have used fairy, persil washing LIQUID, (not powder) to clean water system and it works well. Just keep doing it until clear.
Andy |
Fairy froths up and can cause overheating.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
I'm talking about washing liquid for clothes, just to be clear not the stuff for plates etc.
