Home > In Car Electronics > Why did i cut a hole in my dashboard- Wiring help please |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
I've done something silly, which despite taking a cutter to my 2011 puma dash I don't think is the cause!
Basically I've converted my truck cab to a soft top and cut the movement sensor and interior light into the angled side of the centre dash rather than mount a bracket and have loose wires above the screen. When I did this I had the dash out to check it was clear behind (it was honest!) and since putting it back the radio doesn't work other than to eject cd's (its a jvc unit and has power to it) and the interior light has stopped working at the same time. It went a bit mental on the middle setting then stopped. All the fuses are ok so I've obviously a wire somewhere putting it back in. Anyone got any clues what I've done as might save me a lot of head scratching tomorrow Defender puma dormobile camper |
29th Dec 2013 6:58pm |
All sorted, yes im an idiot luckily it was only the connections that came apart! Defender puma dormobile camper
29th Dec 2013 7:48pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
You should have said mate I have a interior light fabricated plate for soft top propa puma one as we'll laying in the workshop mate I'll show you it when your up at the weekend CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
29th Dec 2013 10:43pm |
Cheers mate, might be a bit late for that now! To be fair it looks pretty neat, im going to have to have a good look at all these bits you've got and around the improved workshop! see you then Defender puma dormobile camper
30th Dec 2013 8:33am |
